メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Motorola Moto Gは、Motorolaの低価格スマートフォンです。スマートフォンのあらゆる機能を半額で実現しています。モデル番号はXT1032、XT1033、XT1036です。
Front camera connector locking tab loose
Hello,
While trying to replace my Motorola Moto G screen, I had to disconnect the front facing camera. Unfortunately, the locking tab came loose. I don't have any idea how to fix this... Could anyone help me?
This is a picture describing my problem: http://i.imgur.com/IjN96kg.jpg
Thanks in advance.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
ベストアンサー
I fixed the problem myself just by using Scotch tape. I didn't really tape the connector to the port to keep it in place, but I put 3 small layers of Scotch tape on top of the connector. Then I inserted the connector. It's not really easy to insert the connector because it got thicker, but that's the reason why it works: the thickness of the connector with the Scotch tape "simulates" the pressure of the locking tab.
TL;DR: put small pieces of tape on top of connector, then insert connector. Test front camera and add layer of tape if necessary until you reach suffising pressure.
Excuse me for my English and good luck to anyone with the same problem :) feel free to contact me if something isn't clear.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have had this happen a couple of times. As long as the tabs on either side of the "door" (black plastic piece that came loose) are intact and not broken off you can somewhat easily re-insert it. Try placing the door at a 90 degree angle and then gently swing it into place. Be careful not to bend the pins in the onboard connector though.
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
Thanks! How can I see which side needs to be facing the pins and which side needs to be facing up?
さんによる
Should be evident when you inspect the door. both sides will appear different. One should have obvious fluting that will seat around the pins on the connector.
さんによる
I really can't get it in there though... Is there any way I could make it work without the lock?
さんによる
Possibly by taping the connection. I definitely would not suggest it though. The door will go back on. As long as it is not damaged it just takes a little perseverance.
さんによる
コメントを追加
hi, in my work i have this issue every day and my solution is reinsert the plastic seal... in 90º degrees but if i lose it, i put a little piece of other plastic like the original piece the funcion is the... same :) great hug from chile
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Wouter さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 16
今までの合計 528
