What is causing lines through some numbers?
When I turn on my ti84 and type in numbers, some appear with vertical lines through some of them, how do I get rid of the lines?
fergam22, that is usually caused by a damaged screen. always make sure that you did a reset and check to make sure that all cables are properly seated. To replace the screen use this guide
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 5
過去 30 日: 21
今までの合計 1,641
