メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
カメラ性能で知られるWindows Phone。Nokia EOS、Nokia 909、Nokia RM-875、Nokia RM-877、Nokia RM-876という名称でも知られています。
Phone not switching on
I was using my phone and then it got switched off due to no charge.
I kept it for charging and tried to switch on my phone but since then its not switched on.
It wont switch on due to some reason.Kindly help.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
Fazal, it is possible that it is just totally discharged. Try a new cable and a different charger. If that does not work, you may have a bad charging connector. In that case, try a new battery or one that has been charged with an external charger to at least get your phone to respond. Consider replacing the charging port. Here is a decent guide for that.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
That video is in no way helpful it doesn't show u how to remove the port I went through the steps a few minutes ago after releasing the 2 screws there is still another part of the flex cable which is behind the speaker and to remove the speaker u would have to break the backcase so my suggestion is to by the back case with the port
さんによる
コメントを追加
回答を追加する
Fazal さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 18
今までの合計 1,024
