メインコンテンツにスキップ
The HTC EVO 3D is an Android smartphone developed by HTC released exclusively in the United States through Sprint.
9回答 すべてを表示
締切られた回答
Why is my battery life bad? Why does my battery not charge?
My battery doesn't last as long as it used to. My battery only lasts a fraction of what it is supposed to and at times it doesn't even charge. Can someone please help me figure out what may exactly be causing this issue?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Your battery is probably damage. In this case, you should go and buy a new one. Also, you will need to check if it correctly installed. In other cases, the fault may be of the charger. If the charger is not working correctly or if it’s broken it won’t charge correctly the battery. Refer to the Troubleshooting Page at www.ifixit.com/Wiki/HTC_Evo_3D_Troubleshooting for more details in order to fix this issue.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
最も参考になった回答
Matthew Pope, sounds like you will require a new battery. This teardown will show you how to get to the battery.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 4
今までの合計 107
