メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HP Pavilion dv4t 14.1インチワイドスクリーンノートパソコン。
Why is my screen pixelated?
I had opened a video for a school assignment and after a while, the video went haywire and now my display looks pixelated. Can you help me figure out what's wrong? I don't want to lose my files but I am unable to see my options on the screen.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Sophia P, could be a bad LCD or a bad GPU. Attach an external monitor and see if that displays properly. If it does, you have a bad LCD. If it does not than you are having issues with your GPU which is part of your logic board. That of course will require some major repair, i.e. logic board replacement or replacement of the GPU itself if you can get a new GPU for a reball..
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Well I plugged a monitor to display and it's still doing the same thing. I just don't understand how a video would do that
さんによる
Sophia P, do not look at it as in the video having caused this directly. The video just pushes the GPU a bit harder to process, If it is already having issues it does not like the being pushed and subsequently fails.
さんによる
Okay well thank you for your help, much appreciated
さんによる
コメントを追加
回答を追加する
Sophia P さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 10
今までの合計 980
