メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
24インチディスプレイ。内蔵iSightカメラ、マイク、スピーカー、1920×1200の解像度。2008年10月発売、モデル番号A1267で識別可能。
Common Logic board burn spot?
Hello
My cinema display started smelling weird and then shut down. I opened it and found the problem to be a burned spot on the logic board. No problem I'll just replace the logic board and then I can use it again.
So I was browsing for a new board when I saw a dutch thread with someones logic board also burned. But the weird thing is that the burn is at the exact same place.
画像
Does anyone have had a problem with a burned board?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
2 件のコメント:
Lukas Guy, it might help if you add some images to your question. That will allow everybody to see where the board gets damaged
さんによる
Hi Lukas Guy, I have a Apple Cinema with probably the same issue. How did you replace this part? Where can i buy this part?
Gr. Vincent (from Holland as well)
さんによる
コメントを追加
1 件の回答
Lukas Guy, that looks like the LED driver. It is most likely a "common" failure if you have a short within the backlight circuitry. Any short there would take out that driver. I would suspect the primary offender would be the LCD connector.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Lukas Guy さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 19
今までの合計 2,812
