メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Sanyoテレビの修理ガイドとサポート。
volume will not work with remote.
Volume can not be controlled with remote. Have to push the buttons manually
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
5 件のコメント
All the buttons on the remote work. I did change the batteries.
The volume bar on television only show when the volume buttons are pushed manually, not when you push the volume button on remote.
さんによる
My Sanyo control volume does not work to turn volume down
さんによる
The vol go up and down by itself
さんによる
Why my 32 inch Sanyo go up and down by itself
さんによる
Volume goes down by itself
さんによる
コメントを追加
4件の回答
最も参考になった回答
Are any of the other buttons working on the remote? Can you change channels or power it off or on?
If only the volume buttons are not working it is likely a problem with the remote control.
First of all, I would replace the batteries in the remote. If the batteries are getting low sometimes they can do flaky things. There may be enough power to make some things work(like power button) and not others (like volume button). Also make sure there is not corrosion in the battery compartment on the battery terminals. Old batteries can cause corrosion and make the batteries not have good contact and not supply adequate power.
If that doesn't work, I would purchase a universal remote and test it. If you did not want to buy a new device, some of the newer Samsung phones have Infrared blasters that allow you to use them as remote controls. You can download free remote control apps.
If a different remote doesn't work. The problem would be in the tv. If that is the case, perhaps someone else here with mnore knowledge than me.could assist with the actual tv repair.
このアンサーは役に立ちましたか?
スコア 2
8 件のコメント:
I can not turn the volume down manually. I replace the remote but still doesn't work what could be the problem
さんによる
My name is LaVerne and I have not been able to adjust the sound with the remote nor manually on certain movies. It is either too low or too high and I am unable to change it.
さんによる
There is nothing wrong with the batteries and yes all the other buttons work
さんによる
It has to be the tv that has the problem
さんによる
My tv is a 40” Sanyo
さんによる
3件以上のコメントを表示
コメントを追加
Does a small panel appear on top right screen saying INPUT and HD . Reset the TV buy unplugging it for a few seconds, then plugging it back in. Fixed my problem..
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Go to the TV settings and change the Remote adaptivity. Keep the Remote on sunlight for 30 minutes this boost the battery power.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
This sounds silly but mine wasn’t working because if you have tooo many thing on top were the señsor is it can’t read it take of all the junk you have on the table or where it’s located and it should work now.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
pam さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 22
今までの合計 13,255
