メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
Touch ID problems with original sensor
Hi guys, basically I smashed my iPhone 6 about a week ago I replaced the screen but in the process I tore the Touch ID extension flex that runs behind the LCD. I ordered a new flex cable from eBay and installed it. Home button now works flawlessly but Touch ID does not. Now when I try to setup a fingerprint it does not say failed or anything, it just acts as if it does not know that I'm touching the sensor. The reach ability function also does not work. I have reseated the cables at least 10 times and have also restore the phone in iTunes, but it still will not work. Please guys can anyone help ?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Try another long flex. As long as your original home button and the little flex is intact, this should be work. eBay parts are often defective.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Yeah I thought to try this, how comes if my long flex is defective when I restored it didn't throw an error 53 though ? Weird huh :D need to get this sorted asap though as Apple pay does not work :( also everything is intact I have look under a magnifying glass the the little Touch ID flex and j can't see anything wrong with it
さんによる
Yes I would think it would throw error 53 with bad long flex. Any chance you damaged the button itself?
さんによる
Don't think so, looked at it under a magnifying glass and it looks fine. No nicks or kinks. Just doesn't work
さんによる
コメントを追加
回答を追加する
Bradley Munro さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 161
