メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Fiat Chrysler Automobiles US LLCのクライスラー部門が製造した自動車およびその他の車両の修理ガイドおよびサポート。
cruise control quit working
nothing works with the cruise, the "cruise on " indicator light doesn't come on when I push the cruise on/off button on steering wheel
2012 town and country
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 5
12 件のコメント
2006 dodge grand caravan. ABS and Break lights come on. I have never used cruise control. Bought it used 3 yes ago. When I turn off the engine the servo unit keeps running. WTD?
さんによる
I read all the comments and I'll be damned if hitting the steering wheel got mine working aswell!!! Woot! I use it ALL THE TIME! Was lost with out it! 2011 Chrysler Town and Country!
さんによる
I can’t believe it…it works! Two hard pounds to the back of the steering wheel near the cruise control switches BOOM ? Thank you to those that answered and commented!
さんによる
It also worked for me. How long? But it worked. Thank you
さんによる
Hello 2014 grand caravan with same issue , a little hit in the steering wheel and works! Thank you
さんによる
7件以上のコメントを表示
コメントを追加
13件の回答
ベストアンサー
john b , Defective speed sensor, bad cruise switch/wire connection, bad brake light switch,etc can cause cruise not to work properly. If engine light on, record the code to help diagnose the issue. You may have to find a good Tech. to diagnose and estimate repair. Good luck.
このアンサーは役に立ちましたか?
スコア 5
53 件のコメント:
Smacking the dash and steering wheel worked for me as well
さんによる
Son of a ##&&%, my cruise wasnt working, so i just smacked dash and steering wheel. Sure as $@$* it started working again lol
さんによる
Smacking the dash and wheel worked for us too! Thanks!
さんによる
Holy s@$&! Smacking the steering wheel worked for me too! I had to try it after reading the comments
さんによる
Holy crap!! Dash & wheel smack on my 2016 just worked for me, too!!!!! I don’t know if I love this or am really upset by it...
さんによる
48件以上のコメントを表示
コメントを追加
最も参考になった回答
I have a 2012 Dodge Charger. The cruise control on off button sticks or doesn't make contact to turn on. I have found that if you whack the steering wheel hard on the back side of the module a few times it will most likely start working again. I know this isn't ideal and the module needs replaced but it does work until you can replace it.
このアンサーは役に立ちましたか?
スコア 20
32 件のコメント:
We are on a long road trip to florida and the cruise quit. Started reading every post about it and found this one. Smacked the side of the steering wheel and I’ll be hanged if it dodnt turn back on.
さんによる
This just happened to me and it worked! Seriously!! Jeremy... did you do anything long term?
さんによる
It worked for me too!
さんによる
Unbelievable I'm driving down the freeway hit the back of my steering wheel and it works
さんによる
10/10. Worked in Canada too. Thanks Barry. You’re a genius.
さんによる
27件以上のコメントを表示
コメントを追加
I have a 2014 T&C. I made a fist and smacked the side of the steering wheel (where the cruise control cluster of buttons is mounted) firmly 2x. I did not hit the buttons themselves or their housing directly. Result? Cruise icon lights up in the dash and cruise function works!
このアンサーは役に立ちましたか?
スコア 7
2 件のコメント:
Omg! It totally works!
さんによる
2011 300 the steering wheel smack worked. Unbelievable.
さんによる
コメントを追加
My wife has a 2012 T & C and turning ON the cruise was intermittent at best. I am an electronics tech, and decided to try spraying some electrical contact cleaner in the air gap around the ON/OFF switch in the steering wheel controls before going to the next level and replacing the switch. After applying the contact cleaner, I then dried it at the same point with a can of compressed air (computer keyboard cleaner). No more issues, cruise switch works every time now.
このアンサーは役に立ちましたか?
スコア 5
9 件のコメント:
Omg it worked for me too. 2012 grand caravan crew. Up here in Canada.
さんによる
I mean hitting the steering column and steering wheel.
さんによる
I have a 2012 crysler 200 cruise works sometimes and sometimes it doesn't what can I do
さんによる
So I thought all the comments above were a joke but.....it actually worked
さんによる
2015 Town & Country. No cruise, read the smack solution. Bam bam, works! Thanks!
さんによる
4件以上のコメントを表示
コメントを追加
I also had a 2012 dodge journey that the cruise control quit working. I followed all the suggestions of checking fuses and break pedal switch and everything else but nothing worked. I then read this thread and went out and slapped the steering wheel by the controls and it started working.. I would highly recommend trying this first before checking anything else. I guess dirt food crumbs or anything else can get behind the buttons and stop it from engaging.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
That's crazy!!! I just tried this and it worked!!! I've been without cruise control for a few weeks. Amazing!!!
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Is the Check Engine light on? Alot of newer cars will disable the cruise control when the check engine light is on .
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
さんによる
コメントを追加
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I removed the switch, opened it and cleaned the tiny connectors that were corroded where they touch the female connector from the wiring. The cruise control worked ever since…
さんによる
コメントを追加
I just worked on replacing brakes then my cruise control would not work. Thought it was a speed sensor but I have no warning lights on. Read these comments and I hit the steering wheel to see if that would fix it. Like magic it works now.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Holy Crap!! I googled this…My 2014 T&C Chrysler, cruise overnight Stopped working. Saw this, tried it, And It did work 🤗
Thank you!
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Was your brake, abs & anti skid lights illuminated at the time?
さんによる
コメントを追加
Just smacked it after driving four hours . WORKED WTF!!
SMACK IT!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Our cruise just went out on our "new" 2013 Caravan as we are headed back home from out of town. My DH loves using cruise control so he just asked me to Google "Grand Caravan cruise control issues." This thread came up and I thought the first comment was a joke. Then every comment was the same. My DH didn't believe it but started smacking the steering wheel. Nothing. One comment said to hit the center of the steering wheel. He said, "it's just the horn" but hit it anyway. The darn cruise control popped on! That is insane. We had a good laugh. Now, we don't know how to feel about this. It is obviously a defect.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
So my brake light went out, my ignition won’t catch til the second time then does immediately, cruise quit,it felt stuck ,not coming back up, smacked it and it felt normal again,orange engine light has been on, had it coded-no issues. One week before this all started the air intake sensor went down. Other than that she’s been running great..still no cruise control
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I have a 2012 Dodge Durango RT. Cruise control stopped working. So glad I found this thread. Banged on the side of the steering wheel near the cruise control buttons. Boom. Like magic, cruise control works like it should! What a fix.
さんによる
コメントを追加
回答を追加する
john b さん、ありがとうございました!
統計データ:
過去 24時間: 6
過去 7 日: 69
過去 30 日: 326
今までの合計 65,967
