メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Motorola Moto Gは、Motorolaの低価格スマートフォンです。スマートフォンのあらゆる機能を半額で実現しています。モデル番号はXT1032、XT1033、XT1036です。
Why is part of my replacement screen unresponsive?
I recently replaced my Moto G's screen with one I found on Amazon.com. For awhile (about 48 hours) it was working flawlessly. Then it started misbehaving. I noticed the touch screen responding poorly. I narrowed it down to one horizontal section of the screen just under the center as unresponsive. I downloaded a touch-test app and confirmed this was the case. However, this is not a permanent condition, as the area sometimes works randomly and other times is completely unresponsive.
Thinking it might be a loose connection, I took my phone apart again and checked the connections. I took the ribbon cables out and put them back in again after cleaning with alcohol. The problem persists.
What could be causing this dead section of my touch screen? And is there a way to fix it?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
ベストアンサー
Its possible the screen is defective, get a replacement and see if it does the same thing.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Peter Pollet さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 14
今までの合計 1,613
