メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
1995年8月28日発売。33MHzプロセッサ搭載。
open firmware on PowerBook 190
How can i boot into the open firmware of a PowerBook 190? I've tried the Cmd+Option+O+F command but it doesn't do anything
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Here's everything you ever wanted to know about open firmware on System 9;
http://www.netneurotic.de/mac/openfirmwa...
このアンサーは役に立ちましたか?
スコア 2
7 件のコメント:
If I'm not mistaken the 190 is a 68K machine and does not have open firmware. + for research. Ralph
さんによる
Ralph, If I remember correctly it was a 33MHz 68LC040 processor. Which means you're right about the 68k cpu, I just don't remember about the open firmware.
さんによる
I was afraid of that... Do you know of anyway to get around the startup disk issue. The exact message is "This startup disk will not work with this Macintosh model. Use the latest installer to update this disk for this model." with a restart button. The computer was working fine but one day it just locked up, shut off, and now this happens everytime it turns on. Also, the hardware seems to be okay as the little happy Mac picture comes up when it turns on too.
さんによる
What startup disk are you trying to use? What other system disks are available to you?
さんによる
As far as I know it should still have the hard disc set as the startup disc (I'm not entirely sure though, I'm not as familiar with a Mac this old). And at the moment, I don't have any system discs that are compatible (as it only has a floppy drive and no way to connect a dvd drive)
さんによる
2件以上のコメントを表示
コメントを追加
回答を追加する
Tanner さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 18
今までの合計 1,229
