メインコンテンツにスキップ
Cobra 29 LTD Classic. 2-way 40 channel CB radio. Features antenna warning indicator, SWR calibration, instant Channel 9, PA capability, dimmer control, switchable noise blanker and RF gain.
8回答 すべてを表示
締切られた回答
Squelch has no white noise
I've got a used Cobra 29 that came with our used truck. The power comes on, but I cannot get any white noise with the squelch all the way to the left. Is that normal for these CBs? I also haven't heard anyone talking, so I'm wondering if it's working at all. Is there a way to test without another CB? Thanks, kevin
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Isn't the speaker damaged?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
No. Sorry. I should have mentioned that the Weather is coming in fine. Just no white noise on the squelch in CB mode.
さんによる
コメントを追加
i am having this problem with my radio. i pullrd the antenna apart and cleaned the corrosion, and made sure the antenna had a clean ground. then i took the radio out and checked the connection on the cb.and found the coax is bad.because i could move it and get a little white noise... so i will be getting a new coax cable. hope this helps.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 3
今までの合計 2,792
