How do I connect a 5.1 speaker system
how do i connect a 5.1 speaker system on this tv?
as the TV has only co-axial and Headphone jacks.
I have an F&D speaker system
http://www.amazon.in/gp/product/B00E2OY9...
Please reply.
この質問は役に立ちましたか?
Please reply.
この質問は役に立ちましたか?
Best option to connect 5.1 home theatre from your TV is to connect through the Digital out COAX output jack at back of your TV but you will require either Digital to Analog Converter or 5.1 converter which you can buy from Amazon. In case you want to connect from your headphone jack out from your TV you can connect through 3.5 mm cable to RCA AUX cable to your home theatre but the sound will be only 2 channels LEFT RIGHT channel out only and low so you can better buy an amplifier for the same.
このアンサーは役に立ちましたか?
same problem for me in vu 32D6475. how to connect 5.1 home theatre? step by step pls guide
IAM also facing same issue in vu32, please explain
My problem solved by fixing of coaxial to RCA convertor to digital out pin in a tv
I have issues for connecting speakers with Vu TV please help and guide for connecting the speaker to TV
過去 24時間: 3
過去 7 日: 15
過去 30 日: 27
今までの合計 22,080
2 件のコメント
how do I select external speaker option in VU 43bu113 TV
Sathish Kumar さんによる
Vutv 32bfm model how to connect 5.1 speaker please explain
dhamu tharan さんによる
