Remove write protection from SD card
How do I remove write protection from SD card please?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
If you look at the SD Card just to the right here you'll see a slider on the left this needs to be up position.
In addition you may need a small piece of tape to cover the right side notch. You do need to be careful here as you don't want the tape to cover the contacts on the other side, nor do you want it to come off inside your reader making a bigger mess!
このアンサーは役に立ちましたか?
Many thanks for this, so simple yet saved me having to buy a new SD.
過去 24時間: 1
過去 7 日: 6
過去 30 日: 36
今までの合計 6,289
