メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsungの人気の7インチタブレットシリーズ、Galaxy Tabの第4世代モデル。
My Samsung Galaxy Tab 4's Screen Is Not Working..
My Tablet is on and the screen is just black with with blurry lines but I haven't been able to use the tablet for almost a year and it was new.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
3 件のコメント
It didn't work :( the screen lights up but there's nothing on the screen except the white lines and black everywhere else.
さんによる
same problem comes in my samsung tab..so what you do??
さんによる
If you can open and remove the back cover of the tablet (or ask a tech guy to open it), check the two cable connectors from the screen to the motherboard. One is the LCD and the other is the digitizer. I don't know which is which because I have seen them on tablets that were damages and disassembled. Maybe one of them is not well seated, so carefully press them down, and power the tablet on to check. You can do this without the back cover on and the battery reconnected.
さんによる
コメントを追加
2件の回答
ベストアンサー
You can try a hard reset this will take you back to new all your data and apps will be lost but at least you should have a working tablet
http://www.technipages.com/galaxy-tab-4-...
This is a walk through on haw to do it. Good Luck
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Screen is not working touch is not working anymore how can I reset it and if I try to reset it with on off button it sucks it can't reset or switch off my tab is galaxy tab a9 plus
さんによる
コメントを追加
If it’s almost a year, and it was new, it will be covered under a warrenty
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jessica Goode さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 9
今までの合計 5,579
