Why my phone cannot turn off?
y phone was suddenly hung-up when I open my email. I press long press to turn off but it doesn't work. It will not turn-off. How can I solve this one? I try to recharge my phone, it doesn't work also.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Press and hold the Volume down and the Power buttons. When the phone reboots, release them.
Regards.
このアンサーは役に立ちましたか?
Dat was really helpful. ..thanks!
its working thank you so much
its good idea..... thank u .....
good job...... i really like u......
it's work... thanks
You could remove the battery and this will kill the phone and hope it boots properly when it restarts once you put the battery back in. Hope this helps and good luck
このアンサーは役に立ちましたか?
in samsung galaxy a5, you cannot remove the battery since the battery is built in.
Many, many thanks
unplug Charger before Turning off ,,
it turns off and doesn't reboot ,,
When it's already switched off..you can Plug in the charger and it won't turn on..
Works for me Samsung Galaxy j7 OS 6.0.1
このアンサーは役に立ちましたか?
Hello .. I forgot my lock pattern and when I try to hard reset it .. won't let me turn it off .. it wants the lock pattern in order to be turned off but I don't remember the pattern .. so .. no hard reset, no nothing .
このアンサーは役に立ちましたか?
Thankyou so much. Totally worked. Only way to power off / shut down your malfunction samsung j 7 prime phone or device. Power & volume - key while its plugged in to charger. Or else it only restarts.
I was so lost, i felt the phone had malfunctions.
Thankyou so much
過去 24時間: 0
過去 7 日: 5
過去 30 日: 27
今までの合計 60,613
28 件のコメント
holding the down volume button and the power button at the same time till the phone vibrates should restart it. if you have it plugged in charging and do this it turns the phone off
Kit さんによる
That was a fantastic clue. works perfect!. Thank You Dude.
daymust2007 さんによる
Wow that really helped me thank you very much
nida12es036 さんによる
worked perfectly. thanks much!!!
obetsky nunez さんによる
Amazing advice! Nothing else worked but this did. Thank you :)
Libs Figg さんによる
23件以上のコメントを表示
