メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
K-Gro PowerProは、MTD社およびMurray社がK-Mart向けに製造した乗用芝刈り機です。1997年に発売されました。モデル番号:13AL452F120(38インチ、12馬力)および13AQ695H120(46インチ、18馬力)。
powerpro drive belt replacement.
Need instruction on drive belt replacement for power pro 18hp 42 in.cut riding mower.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
4 件のコメント
pamelaburgess1958, if it is a K-Gro mower, it will help to get more information. A model number or any other identifier will be important since this is a mower that was most likely build by MTD. Manuals and instructions for this brand is a bit scarce
さんによる
I Ned a Beit for K Gro Power Flow 46" Deck
さんによる
I ned a Manul for a K Gro Power Flow Riding Mower
さんによる
I need the deck belt for a k gro 18 hp riding lawnmower with the 44" cut
さんによる
コメントを追加
2件の回答
ベストアンサー
Replacing the blade drive belt requires completely taking the mowing deck off.
Underneath the deck are the mounting pegs there are clips you remove then the arms pull sideways to remove. Watch your fingers. Repeat on the other side and then if your rider is like mine there are rods at the front and pins you pull. Remove the old belt from the engine pulley and the deck is removed, pull the deck out.
There are plastic pulley guards remove those.
Your tractor I think on the deck has a routing diagram for the belt.
Now is the time to remove debris. There is a pulley that is spring loaded make sure that moves freely.
Reroute your belt using the diagram.
Attach pulley guards move deck under rider, pull deck up reattach all pins etc.
Put the blade drive belt on engine pulley.
BTW on engine pulley there is a guide there you need to make sure belt is under this guide.
BTW the pulleys also have spring loaded guides to keep the belt in place.
The engagement lever has a tension adjustment too I believe.
On the back of the tractor seat are belt numbers I believe there is a place in Las Vegas that has both the
Motion drive belt and blade drive belts.
I'm having a ##&&% of a time trying to get my deck level
Good luck but it's not fun.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
On my 1998 power pro lawn tractor had to replace the belts now I don't know where the two springs go one large spring and one small spring they are heavy duty springs I cannot figure out where they go can anybody help send pictures viperruss 45@gmail.com
さんによる
コメントを追加
Can you help a guy out what size is your belt
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
That is what I am trying to figure out .
What size belt it needs , I was asking you I am asking you for the size
さんによる
コメントを追加
回答を追加する
pamelaburgess1958 さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 8
過去 30 日: 37
今までの合計 5,933
