Why is there a 750GB limitation with an optical drive bay HDD?
I would like to install a 1TB 2.5 HDD in the optical bay slot (Macbook Pro Unibody mid 2012).
I currently have a 500GB HDD in the optical bay and a 500GB SSD in the original hard drive bay.
I am curious to the 750 GB limitation that is noted in the description.
Product Code: IF107-080-3
Update
The specs:
2012 macbook pro
10.10.3 OS X
4 GB Ram
2.53Ghz Quad I7
500 SSD has 1 OS partition
500 HDD 5400 RPM has 1 data partition
1 TB HDD 7200RPM has multiple partitions
Initial config:
500 SSD in HDD bay
500 HDD (original drive) in Optical bay
Benchmark SSD:Write 1024KB (451.306 MB/sec) Max
Results:
500 SSD boots properly
500 HDD reads and writes properly
New Configuration 1:
500 SSD in Optical Bay
1TB HDD in HDD bay
Results:
the 1 TB drive worked fine.
The 500 SDD (with the primary OS partition) had difficulty booting. After several attempts, the SDD booted to the OS. I attempted to run a benchmark test. The results were sporadic and had several force restarts.
Benchmark SSD:Not stable enough to officially record
New Configuration 2:
500 SSD in HDD bay
1 TB HDD in Optical bay
Results:
The SSD worked fine.
After booting to OS (using SSD), the 1 TB drive requested that I Initialize the drive. (Disk utility shows the individual partitions (disk1s1 etc) without any names) Occasionally, a single partition will mount and it is not always the same partition that mounts from that drive.
If a 1TB drive works, maybe it needs to be <7200 Rpm?
この質問は役に立ちましたか?
4 件のコメント
If you have a question about a particular product, please give a link to it so I don't have to spend ten minutes hunting it down. This forum is manned by volunteers, not by iFixit employees.
mayer さんによる
My apologies.
hUnibody Laptop Dual Drive
kcme94399 さんによる
You could install your 500GB SSD in the optical bay and the 1TB HDD in the original HDD bay..
Rany さんによる
You could… but that would be counter-productive :( The optical bay bus runs slower than the other one on the machines. They were the same on later models.
Fred Bloggs さんによる
