メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Best BuyのブランドであるInsignia製タブレットの修理ガイドおよびサポート情報。
tablet will not turn on
it not comeing on and yes it is fully charged
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 11
5 件のコメント
I purchased 3 tablets for my chandchilden. They will not charge at all. The screen remains black
さんによる
I Lt doesn't turn on or anything I've been charging for 3 days know and nothing
さんによる
My Tablet will not even turn on and the screen is still black, What should i do?
さんによる
My tablet will not charge while in the charger. It will decrease the charge instead of the other way around so I'm not sure what I should do about it and it's like 6% I think right now not sure if I need a new battery or if there's a way to fix it I just wanted to let you know I asked you what I should do let me know?
さんによる
i don't want to reset my tablet!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
さんによる
コメントを追加
3件の回答
ベストアンサー
If all else fails you can try a hard reset which will wipe all your data and start you from new. This is done by pressing the start button and the up volume button at the same time . Hold them both down till the machine starts . you will see probably the android and then a selection menu . Use your volume to scroll up and down the menu . Select factory reset and then yes wipe data and it will reformat the tablet and it will start from new. Hope this helps.
このアンサーは役に立ちましたか?
スコア 8
8 件のコメント:
how do you remove the battery?
さんによる
This one requires soldering to remove but if your hand with an iron this will help
Insignia Flex 10.1 NS-P10A6100のバッテリー交換
さんによる
It doesn't turn on should we charger it or what??
さんによる
Or how long to take to turn on
さんによる
It will not charge!?
さんによる
3件以上のコメントを表示
コメントを追加
Try removing the battery. With the battery out hold the power button down for 60 seconds. But the battery back in and try turning it back on. If the light comes on the LCD screen could be ruined. Might have to change that. But doing the first step i said fixes quite a few issues.
このアンサーは役に立ちましたか?
スコア 3
6 件のコメント:
How to remove it
さんによる
Yeah how do u remove it
さんによる
Wow Tyler Black thanks so much this helped it totally worked i tried taking battery out but would come out but just took the back of the tablet off and did what you said and it came right on thanks
さんによる
my tablet is fully charged but not starting
さんによる
my iPad is not working because it has a little crack in the back and I'm clicking the power button for 60 seconds and then not working
さんによる
1以上のコメントを表示
コメントを追加
Check the place where you plug in the charger. Sometimes the prong inside gets a tiny bent. Wiggle it a bit with some tweezers and you should be good to go. I used to refurbish tablets and it happens with all brands. This may also work on your phone if you ever have the same problem.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
It is very annoying to reset your device and lose everything so try this first! Also to clean it a lightly damp q tip of alcohol will do the trick
さんによる
How can you reset it if the screen does not open. It is pretty hard to reset when the screen is black.
さんによる
コメントを追加
回答を追加する
jloza84 さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 9
過去 30 日: 20
今までの合計 47,203
