メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Apple 製の外付け光学ドライブです。本質的には MacBook Air SuperDrive を刷新したものです。
Device will not display
After putting disc in SuperDrive no device display appears on computer screen and so cannot eject disc.
How can I eject disc either by getting drive to display or open drive and manually eject?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 6
4 件のコメント
What do you have it hooked up to?
さんによる 共有
2020 iMac 27"
さんによる 共有
2020 iMac 27" screen @mayer
さんによる 共有
@democratic hope - Go under Finder, to the left of the Apple in the upper left hand corner to Preferences. Click on general > CDs DVDs, and iPods. See if the icons shows up on the desktop. Drag it to the trash, or click once on it and go under File > eject. this failing restart and hold down the mouse button.
さんによる 共有
コメントを追加
2件の回答
ベストアンサー
Hooked up to MacBook Air
このアンサーは役に立ちましたか?
スコア 1
5 件のコメント:
Is the drive meant to show up like usb do?
さんによる 共有
Go under Finder, to the left of the Apple in the upper left hand corner to Preferences. Click on general > CDs DVDs, and iPods. See if the icons shows up on the desktop. Drag it to the trash, or click once on it and go under File > eject. this failing restart and hold down the trackpad button.
さんによる 共有
I thought my SuperDrive had broken, as my MacBook Air no longer found it when it was connected, not in finder despite audio disc inside it, and the drive not making any noise at all. So I bought a new SuperDrive. Same problem, so I phoned Apple support and six different people have failed to fix it. Looking on google I saw one solution, restart the macBook with the SuperDrive already connected - success! I copied the CD and ejected it. However that is the ONLY way I can get it to work - it has to be connected at startup, and wont be recognised after that if disconnected and reconnected again. The old drive is the same. Any fix appreciated, thanks
さんによる 共有
I also think mine is broken cannot get through in any way? any suggestions what to do?
さんによる 共有
Apple found and fixed the problem - there was an extension on my Mac called RIMBBUSB.kext which was the cause, and deleting that fixed it. Apparently it is part of Blackberry software, which makes no sense in my case as I don't have a Blackberry. I did use a friend's dongle before this problem and wonder if the software was downloaded by that.
さんによる 共有
コメントを追加
Have owned Apple laptop computers for 15 years, and absolutely loved my first two computers. This third computer, a MacBook Air, purchased in the summer of 2020, has been nothing but trouble. My USB Superdrive failed to eject twice. Apple team’s solution was to order me a new Superdrive. Now the new Superdrive which I’ve had for less than two months is failing again. Same problem again! None of the online suggestions help me. The same problem, but always with a different disk too!
Also worth mentioning that I had a hassle trying to order my computer in the summer. Placed my order three times. Had to contact Apple’s president myself to place the order.
Won’t ever buy another Mac.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Joe Rickertsen さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 23
今までの合計 18,230
