Looking for new HD for iMac
iMac Intel 20" EMC 2210
What is the part # for the 1TB or 2 TB drive and how can I order it?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
with this upgrade you do have two options. 1. you can replace the internal hdd with a larger 1 or 2 tb hdd as long as it is 3.5"(standard desktop size) and SATA(serial ATA). or 2. you can use an enclosure to remove you superdrive and add a second hard drive, but it would require a 2.5" hard drive(standard laptop size).
I have linked the i fixit guides below for both options.
ガイド
難易度:
中レベル
1 hour
ガイド
難易度:
中レベル
このアンサーは役に立ちましたか?
The needed part numbers are listed in the links wesley posted here.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 70
