メインコンテンツにスキップ
Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive
必要な工具と部品
  1. Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive, Access Door: 手順 1、 1の画像 1
    • Loosen the single Phillips screw in the center of the access door.
    • This screw is captive in the access door.
    • Remove the access door from your iMac.
  2. Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive, Glass Panel: 手順 2、 2の画像 1 Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive, Glass Panel: 手順 2、 2の画像 2
    この手順で使用する道具:
    Heavy-Duty Suction Cups (Pair)
    $14.95
    • The glass panel is fixed onto the front bezel with fourteen magnets around its perimeter.
    • Stick two suction cups to opposing corners of the glass panel.
    • To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel. While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle.
    • If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent such as Windex.
  3. Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive: 手順 3、 1の画像 1
    • Gently pull the glass panel straight up off the iMac.
    • The glass panel has several positioning pins around its perimeter. To avoid shearing these pins off the glass panel, be sure to only pull straight up during removal.
    • Be meticulous about cleaning the LCD and the inside face of the glass panel before reinstallation, as any fingerprints or dust trapped inside will be annoyingly visible when the display is on. Placing the glass flat, inside face down, on a fresh aluminum-foil surface is a good way to keep it clean.
  4. Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive, Front Bezel: 手順 4、 1の画像 1
    • Remove the following 12 screws securing the front bezel to the rear case:
    • Eight 13 mm T8 Torx.
    • Four 25 mm T8 Torx.
  5. Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive: 手順 5、 1の画像 1
    • Place your hands at the top corners of the bezel (to the side) and lift the bezel 2-3cm from the body by working from the top. After this you can also disengage the bottom of the bezel (the memory modules will prevent the bottom of the bezel to detach first). When reassembling, start with the bottom of the bezel.
    • The top of the bezel hosts a microphone attached to the logic board. Gently lift the bezel to not damage the microphone wiring or connector by accidentally pulling the cable.
    • At this point, you can either detach the microphone cable and remove the bezel, or keep the microphone cable attached and rest the bezel on your work surface or the chassis of the Mac.
    • To fully detach the bezel: disconnect the microphone cable connector, removing tape as necessary.
    • To keep it attached, leave the microphone cable attached to the logic board, and place the bezel 'above' the chassis, with the microphone cable forming a hinge.
    • If you keep the microphone attached to the chassis, make sure you don't accidentally damage the microphone or logic board by bumping into the loose bezel.
  6. Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive: 手順 6、 2の画像 1 Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive: 手順 6、 2の画像 2
    • When reassembling the bezel:
    • be sure to tuck the microphone cable and connector into the void next to the camera board.
    • Gently guide the microphone connector and cables through the ±1in long slot at the right of the iSight camera. Once the bezel is properly assembled, gently push the microphone connector and cable into the bezel through that slot.
  7. Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive, Display Panel: 手順 7、 2の画像 1 Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive, Display Panel: 手順 7、 2の画像 2
    • Pull the LCD temperature sensor connector straight up out of its socket on the logic board.
    • If necessary, de-route the LCD temperature sensor cable from behind the logic board.
    • When you remove the LCD, check the routing of the LCD temperature display cable. On reinstalling the display, be sure this cable does not block one of the bottom screws for the front bezel.
  8. Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive: 手順 8、 1の画像 1
    • Remove the two 5.3 mm T6 Torx screws securing the data display cable to the logic board.
  9. Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive: 手順 9、 1の画像 1
    • Use the attached black tab to pull the data display cable connector away from the logic board.
  10. Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive: 手順 10、 2の画像 1 Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive: 手順 10、 2の画像 2
    • Remove the eight 12 mm T8 Torx screws securing the display panel to the rear case.
    • Depending on the age of your driver, a T9 Torx bit may fit better.
    • Lift the display panel from its left edge and rotate it toward the right edge of the iMac.
  11. Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive: 手順 11、 2の画像 1 Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive: 手順 11、 2の画像 2
    • With the display panel still lifted, disconnect the four inverter cables.
    • During reinstallation, place the four inverter cable connectors in voids between components attached to the rear panel so the display panel will sit flush.
    • During reassembly, the order of the inverter cables is interchangeable within each socket.
    • If you are replacing a hard drive and have an extra set of hands, it is possible to reach in and remove the drive without disconnecting anything but the LCD temp and display connector in the previous step with the LCD in its propped position.
  12. Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive, Optical Drive: 手順 12、 1の画像 1
    • If necessary, remove the pieces of tape securing the hard drive/optical drive thermal sensor cables to your iMac.
  13. Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive: 手順 13、 1の画像 1
    • Disconnect the optical drive thermal sensor connector from the logic board by pulling its connector toward the top of your iMac.
    • When removing this connector, it is helpful to use your thumbnails to push the ears on either side of the connector toward the top of your iMac.
  14. Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive: 手順 14、 1の画像 1
    • Remove the two fine-thread 7 mm T10 Torx screws securing the optical drive to the rear case.
  15. Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive: 手順 15、 1の画像 1
    • Lift the free end of the optical drive slightly out of the rear case.
    • Remove the two 3.5 mm T6 Torx screws securing the optical drive connector to the optical drive.
  16. Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive: 手順 16、 2の画像 1 Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive: 手順 16、 2の画像 2
    • Insert the flat end of a spudger between the optical drive connector and the body of the optical drive.
    • Twist the spudger to separate the connector from the optical drive.
    • It may be necessary to work from alternating sides of the connector until it is disconnected.
  17. Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive: 手順 17、 1の画像 1
    • Lift the optical drive out of the rear case and pull it away from the side of the rear case to release the strip of EMI tape attached to its surface.
    • The optical drive thermal sensor is still attached to the underside of the optical drive.
  18. Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive, Optical Drive: 手順 18、 2の画像 1 Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive, Optical Drive: 手順 18、 2の画像 2
    • If necessary, remove the piece of foam tape covering the optical drive thermal sensor.
    • To remove the optical drive thermal sensor, use the tip of a spudger to lift the center finger of the thermal sensor bracket while applying slight tension to the thermal sensor cable.
    • If your thermal sensor is stuck to the optical drive, skip to the next step.
  19. Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive: 手順 19、 1の画像 1
    • Use the flat end of a spudger to pry the optical drive thermal sensor bracket up off the adhesive securing it to the optical drive.
    • If the adhesive gets dirty or will not stick to your new optical drive, place some double-sided tape under the two semicircular ears of the thermal sensor bracket.
  20. Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive: 手順 20、 1の画像 1
    • Use a spudger to remove the small piece of EMI foam from the bottom of the optical drive.
    • Don't forget to transfer this to your new optical drive.
  21. Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive: 手順 21、 2の画像 1 Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive: 手順 21、 2の画像 2
    • Remove the two 6.5 mm T10 Torx screws from both sides of the optical drive (four screws total).
  22. Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive: 手順 22、 1の画像 1
    • Peel the strip of EMI tape off the optical drive.
  23. Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive: 手順 23、 2の画像 1 Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive: 手順 23、 2の画像 2
    • Slightly rotate the optical drive bracket away from the optical drive.
    • Pull the optical drive bracket away from the open end of the optical drive, minding any tabs that may get caught.
    • If you have a disk or anything else stuck inside your optical drive, we have a guide to fix it.
  24. Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive, Optical Drive Enclosure Faceplate: 手順 24、 1の画像 1
    • Remove the three 3.0 mm Phillips screws from the optical bay enclosure.
  25. Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive: 手順 25、 3の画像 1 Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive: 手順 25、 3の画像 2 Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive: 手順 25、 3の画像 3
    • Starting from the left edge, gently pull open the optical bay enclosure.
    • Continue to pull open the two halves of the enclosure until they separate.
  26. Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive: 手順 26、 1の画像 1
    • Remove the two 3.0 mm Phillips screws securing the faceplate to the optical bay enclosure.
  27. Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive: 手順 27、 3の画像 1 Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive: 手順 27、 3の画像 2 Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive: 手順 27、 3の画像 3
    • Lift the black plastic faceplate out of the optical bay enclosure.
    • You will no longer need the faceplate or the two Phillips screws that held it in place. Set those parts aside if you ever wish to put the faceplate back into the enclosure.
    • Reassemble the optical bay enclosure without the faceplate, reusing the original three 3.0 mm Phillips screws to keep it intact.
  28. Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive, Dual Hard Drive: 手順 28、 2の画像 1 Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive, Dual Hard Drive: 手順 28、 2の画像 2
    • Remove the plastic positioner from the optical bay hard drive enclosure by pressing in on one of the clips on either side and lifting it up and out of the enclosure.
  29. Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive: 手順 29、 3の画像 1 Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive: 手順 29、 3の画像 2 Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive: 手順 29、 3の画像 3
    • Make sure that the hard drive connectors are facing down before placing it into the enclosure.
    • Gently place the hard drive into the enclosure's hard drive slot.
    • While firmly holding the enclosure in place with one hand, use your other hand to press the hard drive into the enclosure connectors.
  30. Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive: 手順 30、 2の画像 1 Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive: 手順 30、 2の画像 2
    • Once the hard drive is snug, reinsert the plastic positioner while holding the hard drive against the bottom of the enclosure.
    • Reconnect any cables you have removed from the original optical drive onto the optical bay enclosure.
終わりに
64 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Brittany McCrigler
メンバー登録日: 03/05/12
89,868 ポイント
142のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
118 メンバー
19,649のガイドは作成済み
10件のガイドコメント
my iMac2008early dvdrom is PATA!!!!!!
plz fix you page!!!
Pak Ho Leung - 返信
I'd sound a caution before replacing the optical drive with anything else if it's on PATA. It'll be slow... Better using an external enclosure and FW800.
markstoter - 返信
I have an iMac early 2008. Do you recommended to replace the optical super drive super with an SSD?
Fabio ABATAR - 返信
Cool. It worked nicely. I replaced the superdrive with an SSD. As expected, due to the slow PATA connection, speed increase is not as dramatic as one would expect with a SATA.
arthurgruber - 返信
i followed this guide but i replaced original 3,5 hard drive with ssd and i replace optical drive (PATA) with a 2,5 hard drive 500gb 7200 rpm sata with an adapter bay
and made fusion drive, now iMac start in 15 seconds and it come back to life
MacAlle - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 16
過去 30 日: 109
今までの合計 81,573
