メインコンテンツにスキップ
Cradle Audio System with separate subwoofer. Sony's first speaker system with integrated iPod dock.
Why is my speaker making a weird noise?
When I try to play music, the speakers make a buzzing noise. It does this both when using an iPod and when using the auxiliary cord. What should I do to fix this?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
1 件の回答
ベストアンサー
The most likely cause of this problem is that one of your speakers is blown. You now need to determine which speaker is blown. Play music through the speakers and try to listen to one side at a time to determine if it is the left or right speaker.
If you want to double check that you picked the broken speaker, remove that speaker and play music again. If the sound seems clear, you chose the correct speaker.
Follow this guide for step by step instructions to replace the blown speaker, or check out the troubleshooting page for further help.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Sarah Means さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 1,475
