メインコンテンツにスキップ
Sony CPF-IP001 Main Speakers Replacement
必要な工具と部品
  1. Sony CPF-IP001 Main Speakers Replacement, Main Speaker Housing Disassembly: 手順 1、 1の画像 1
    • Remove two 6mm Phillips #0 screws.
    • Remove two 7.5 mm Phillips #0 screws.
    • Remove seven 4 mm Phillips #0 screws.
  2. Sony CPF-IP001 Main Speakers Replacement: 手順 2、 3の画像 1 Sony CPF-IP001 Main Speakers Replacement: 手順 2、 3の画像 2 Sony CPF-IP001 Main Speakers Replacement: 手順 2、 3の画像 3
    • Remove six 4 mm Phillips #0 screws from the metal backing.
    • Remove six 5 mm Phillips #0 screws from the metal backing.
    • Using the plastic opening tool, remove the metal plate from the main speaker by gently pulling on it.
  3. Sony CPF-IP001 Main Speakers Replacement: 手順 3、 2の画像 1 Sony CPF-IP001 Main Speakers Replacement: 手順 3、 2の画像 2
    • Remove the plastic dock cover by using two fingers to push the attached metal piece forward and slide it out of the holes.
  4. Sony CPF-IP001 Main Speakers Replacement: 手順 4、 3の画像 1 Sony CPF-IP001 Main Speakers Replacement: 手順 4、 3の画像 2 Sony CPF-IP001 Main Speakers Replacement: 手順 4、 3の画像 3
    この手順で使用する道具:
    • Using the plastic opening tool, detach the wires connected to the metal plate
    • When disconnecting the wires, be careful not to pull on the wires themselves. Use the plastic opening tool and the connector to disconnect it.
    • Use the plastic opening tool to remove wires connected to the circuit board on the far right.
    • Use the tweezers to remove wires connected to the circuit board in between the two black wires.
    • Use the tweezers to press the release tab on the front and back of the plastic white wire head.
    • Once the tab is pressed on both sides, lift up to slide wire head out of socket.
  5. Sony CPF-IP001 Main Speakers Replacement: 手順 5、 1の画像 1
    • Remove two 5 mm Phillips #0 screws.
  6. Sony CPF-IP001 Main Speakers Replacement: 手順 6、 3の画像 1 Sony CPF-IP001 Main Speakers Replacement: 手順 6、 3の画像 2 Sony CPF-IP001 Main Speakers Replacement: 手順 6、 3の画像 3
    • Using the metal spudger, loosen the metal cap at the end of the speaker.
    • Slide down the loosened cap to remove it from the end of the speaker.
    • Simultaneously push down on the buttons and slide the speaker out from the casing.
  7. Sony CPF-IP001 Main Speakers Replacement, Main Speakers: 手順 7、 2の画像 1 Sony CPF-IP001 Main Speakers Replacement, Main Speakers: 手順 7、 2の画像 2
    • Remove eight 5 mm Phillips #0 screws.
  8. Sony CPF-IP001 Main Speakers Replacement: 手順 8、 2の画像 1 Sony CPF-IP001 Main Speakers Replacement: 手順 8、 2の画像 2
    • Gently pry the speaker out from the housing using the metal spudger.
    • Use wire cutters to cut the red and black wires, or desolder the speaker wires to remove the speaker. See iFixit's guide on How To Solder and Desolder Connections.
終わりに
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Marlena Perez
メンバー登録日: 04/14/15
442 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 6-14, Maness Spring 2015 Cal Poly, Team 6-14, Maness Spring 2015人のメンバー
CPSU-MANESS-S15S6G14
4 メンバー
8のガイドは作成済み
1件のガイドコメント
Hi! Does anybody happen to know the model of the speakers? (Or a compatible replacement). I want to give this guide a try and replace my speakers. Thanks!
alecambo - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 6
今までの合計 584
