My camera flash is not working, any way I can fix it?
My camera's flash is not working yet I can still take pictures. I think it might just be broken.
First, I would make sure that the flash setting is on. If it is not on, then the flash will not work. Sometimes the flash will not go off if the camera battery is low. Therefore, try charging the camera and see if that fixes the problem. If those do not work, it could be an internal problem or the bulb burned out.
Here is the Canon Powershot SX50 HS Troubleshooting Page for additional information.
このアンサーは役に立ちましたか?
If the bulb is burned out take a look at a Canon Powershot SX50 HS Flash Replacement Guide.
このアンサーは役に立ちましたか?
過去 24時間: 3
過去 7 日: 19
過去 30 日: 84
今までの合計 9,904
