メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5cの修理情報とガイドです。モデル A1532, A1456
1236回答 すべてを表示
Dropped phone now blank and screens popping out
So a few days ago I dropped my phone and the screen popped out of the iphone mainframe, I popped it back in but now the screen wont work and I can press down the phone like its still not in properly. Siri still works and I can hear things but when I tried to hard boot it, it stopped responding completely. What do I do?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 7
2 件のコメント:
did you solve this bc i have the same issue and i was wondering what did you do?
さんによる
Replacing the screen is what you do if you already tried reseating the front panel connectors. The LCD cable is fragile on the 5c and can easily rip on drop.
さんによる
コメントを追加
4件の回答
One solution to your problem is to make sure that the connection between the display module and the logic board of the phone is intact. Dropping the phone may have dislodged the connection, with continued use causing the internal cable to disconnect. Follow the iFixit iPhone 5c Display Assembly Repair Guide for help finding the connectors for the Front Panel.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I have the same problem but when I popped my screen back in it had a black splodge in the screen display I don't know what it is
さんによる
Means the screen LCD display is damaged. Since the LCD and digitizer are fused together you will need a iPhone 5c Front Panel Replacement.
さんによる
コメントを追加
Use this guide but stop at level 8 and do it backwards
iPhone 5c LCDとデジタイザの交換
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
well same thing had happened here but what i did was hold the home button while holding the power off button and it worked and i was like freaking out before but it worked so i hope this help ^.^
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
well what i did to fix it was hold the home an d power off button at the same time and well ah it was fixed hope it helps bye. ^>^
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Toy Freddy Fazbear さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 13,495
