メインコンテンツにスキップ
The Samsung Galaxy Tab 2 10.1 is a 10.1-inch Android-based tablet computer and belongs to the second generation of the Samsung Galaxy Tab series.
My Tablet just stopped working . will not allow charging
Tablet has turned off and will not boot up via charger. The table is several years old could it be the battery and can it be replaced?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 13
3 件のコメント
how to change battery...open tablet case
さんによる
Tablet just turned off has charge cant turn back on
さんによる
My samsung galaxy tab e is stuck in the ABD update sidescreen. Or i can just let it die. Have amy answers?
さんによる
コメントを追加
3件の回答
ベストアンサー
Try connecting it to different power sources and see if you're able to get any activity to show on the screen. Do you see any status lights or icons on the screen when you plug it in?
このアンサーは役に立ちましたか?
スコア 4
6 件のコメント:
On my tablet it does a battery icon
さんによる
I love my samsung tablet & I've only had it seven months. All of a sudden it won't charge. I've tried different chargers. It doesn't help. I can't even get the back off to look at battery. Very frustrating & no clue what to do.
さんによる
Have the very same problem..waiting for an answer. Let's hope we get one.
さんによる
Thanks for this, been a while since we could afford a new device so this article really helped us save a few $$$. Thanks!
さんによる
Open your Tab, remove small black plug leave it off for 10-15 sec.
Attatch it again. close Tablet and start charging.
Remember not to drain your battery hereafter, otherwise you have to do this operation each and every time.
Se tube vid here.
https://www.youtube.com/watch?v=gMTp2BIx...
Ronny
さんによる
1以上のコメントを表示
コメントを追加
I had same issue, with one of my samsung tablets.
I found out that if i open up then tablet, disconnect the small battery cable for 10-15 sec, re-attatche the cable, the problem is solved. And i can charge again.
Just making sure NEVER to let the tablet completly loos power, always make sure that there is power on battery.
But much better to replace the battery.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
My tablet is 4 months old. Bought it brand new from at&t won't charge . Doesn't work. Gonna try opening and disconnect for 15 seconds then reconmect.
さんによる
how to change battery on tab 7
さんによる
コメントを追加
I have the same problem. Good charger, new battery and charge port. Works great unless my wife runs the battery down. Random actions led me to open it up and unplug the battery and plug it back. And it worked! Have had to do that twice now when battery runs completely out. Didn't used to do that when it was newer though, so something is still amiss.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
how do you
open the back
さんによる
At the edge of the screen, just pull it apart with your fingernails then insert a small plastic tool and open it some more and work your way around. These just snap open, much easier than the I-pads which are glued down.
さんによる
コメントを追加
回答を追加する
JoAnn Heil さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 20
今までの合計 29,069
