メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
24インチディスプレイ。内蔵iSightカメラ、マイク、スピーカー、1920×1200の解像度。2008年10月発売、モデル番号A1267で識別可能。
Flickering band running down display
I have a band about 1 inch wide going down the right side of my Apple flat panel monitor. It looks like very thin white lines constantly flickering on the screen. Is this indicative of a bad DVI cable or a problem with the screen itself? Any information would be helpful.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
5件の回答
最も参考になった回答
I Have seen this in my brother's laptop, some forums say it is a display panel issue, others say it is a video-ram issue, try hooking up annother display, if it does the same, your computers graphics card is bad, also, which apple display, is it a Studio Display (3 Legged Picture frame like thing with powermac G4's and early G5's) or is it a Cinima Display (Newer Aluminum Displays Matching The PowerMac G5 and Mac Pro) or is it a LED Cinima Display( newer LED Backlight with a Mini-Displayport connector for MacBooks and Mac Mini's)?
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Oops, if it's external, than it won't be the video card causing the problem. I thought it was a MacBook display. Anyway, it seems like you have a bad panel.
さんによる
コメントを追加
Try with a different DVI cable and different input computers to see if it is the screen. If it works with a different cable/computer then the display is fine. If the problem remains the display is broke and I think when that happens you need a new one.
Someone correct me if there is a way of repairing a LCD
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
the dvi cable is built into your monitor, so its hard to replace that... could be a bad pin on it or a bad inverter assembly inside. theres not much you can do to fix it without some specialized apple or lcd repair shop that deals in re cabling the screens
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Have you tried attaching your display to another computer to see if the trouble still occurs?
If it doesn't you have a display driver/hardware issue that you need to address.
If it does, you are in some trouble. With a built-in cable, all you might be able to do yourself is open the monitor up and see if the connection is good on the monitor side, and reattach as necessary.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
does anybody know the serial number ?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Dash さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 19
今までの合計 7,288
