How do I replace my track pad button?
Mouse pad Button is stuck and I need a replacement, donor or otherwise. Please advise.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
A less expensive answer if you want to go that way would be to simply use an external USB mouse. If the button is stuck in the on position you may need to disconnect the trackpad cable to operate properly. Ralph
このアンサーは役に立ちましたか?
I am using a new answer because I can't leave a URL in comment.
If you do want to replace the upper case here is a source. Ralph
このアンサーは役に立ちましたか?
For the record I tried three times to leave this as a comment but the program would not allow me to leave a "clickable" url. Ralph
So it isn't just me! If it happens to everyone I'll mention it on the uservoice
過去 24時間: 0
過去 7 日: 3
過去 30 日: 14
今までの合計 3,537
