Touchscreen is not responding
The touchscreen is not responding to input. The tablet turns on fine, but it won't let me do anything with the touchscreen. Help please?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
You can try to reset your tablet by holding down the power button for a few seconds. It will prompt you whether or not you would like to turn off the device and if you can select the off button, this will power down your device.
If your tablet still does not respond your tablet may need to be reset using the factory reset button located on the back. You can press this button with an unbent paperclip. Hold for a few seconds and then try to turn the tablet on again.
If your screen still does not work you may have a broken digitizer. If this is the case you will need to replace the digitizer. This can be done by following the digitizer replacement guide. (A link to this page will be added later)
このアンサーは役に立ちましたか?
I'm having the same problem . Over and over again I reboot it and reset it. Nothing , I tab on the screen and it won't respond to my touch. I have an apex solo 7.85 android tablet. It's been like this for a year . I've tryed taking it back but got nowhere . Plz help me . I want to be able to fix it.
Sincere,
Jaysie Justiniano
このアンサーは役に立ちましたか?
Where can I get a digitizer.
過去 24時間: 1
過去 7 日: 5
過去 30 日: 25
今までの合計 3,751
