メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2014年6月に発売されたSamsung Galaxy S5 Activeのモデル番号はSM- G870Aです。このデバイスの修理は大規模に渡り、ヒートガンとスマートフォン専用のツールキットが必要です。
USB Charging Port Cover/Flap replacement?
Just checking how to replace the S5 Active's USB port flap. The regular S5 looks pretty easy but the S5 Active doesn't have a screw close to the flap.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
5件の回答
最も参考になった回答
Thank you! I've had the cover/flap on by Gorillia tape since i posted up here and hs worked pretty well. The S5 Active covers are ridiculously expensive compared to the regular S5 so I haven't taken it on yet but might soon.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
ATT provides free replacement, I know that much
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Did they send back to Samsung to fix or there in store? Plus locally the closest AT&T service center is an hour away.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Check out this thread Repair/Replace USB Charging Port
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Don't know about the Active. I have an S5 Sport. My port cover flap broke right in the middle. The extension that forms the hinge / retainer stud is a tough but flexible material. It stretches. I grabbed it as close to the little opening as I could with a pair of needle-nose pliers, pulled it slowly, it stretched, I choked up, pulled some more, it stretched, I choked up, pulled some more and it popped right out. I had purchased a replacement cover online, about $10. I was able to press that into the hole using a pair of precision screwdrivers. The whole thing took about 5 minutes. I was afraid the little piece that forms the retaining stud would break off inside the phone. That did not happen to me. If it happens to you, you won't be any worse off than you were before.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
MattCFII さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 34
今までの合計 5,112
