メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
Screw size guide or chart?
Does anyone have any information on the screw sizes on the iPhone 6. Particularly the 5 screws that hold the lcd,digitzer, home button and speaker flex metal bracket/plate down. Going back to the iPhone 5 I remember that using the wrong screw size can lead to damaging the motherboard. Sometimes the screws can get muddled up for whatever reason so I'd like to be sure I always use the correct screws when replacing screens etc. Any help on this would be very appreciated. Thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 18
コメントを追加
4件の回答
ベストアンサー
craigad24, just use the guides like this one. Each step will have the screw size listed in it.
このアンサーは役に立ちましたか?
スコア 12
6 件のコメント:
Who can tell the difference in 1.2 and 1.7 mm? PLEASE SOMEONE WITH PICTURES THAT WE CAN PRINT OUT! And while you are at it make a printable map for each. One of you has it done already. Even if they weren't life size pictures of the screws comparing them would help! I don't care if you tech dudes think I'm an idiot, I am when it comes to this. (at least I can skateboard!)
さんによる
I don't think anybody on here thinks you are an idiot. You are right, a difference of a mere 0.5 mm is hard to spot by eye. I would use an inexpensive set of calipers for that. Sometimes you can spot the difference by comparing the screws side by side.
さんによる
my husband has a caliper that i used to measure the screws....you just have to find a site that has the right screw size
さんによる
Eyeball both of the screw's and take a guess which you think is the longer one. Then verify your visual by getting a small cheap level from the dollar store. Stand both screws up. Put the level on top of the screw's. That should tell you which is the taller of the two. Flip the level left to right and up and down to make sure. Just an inexpensive idea that should/might work for $1.
さんによる
1以上のコメントを表示
コメントを追加
I measured these using a digital caliber. This is off of an iPhone 6, 4.7screen. I measured the entire screw length. The measurement is for the entire screw length
このアンサーは役に立ちましたか?
スコア 10
6 件のコメント:
Thanks! Putting them side by side with a magnifying glass I could guess 1.32 v 1.34.
さんによる
could you guide me on actually how to use the digital calipers on screws , i gave up and bought the caliper just for this project
さんによる
A good video would be https://www.youtube.com/watch?v=oJy8S6r2.... Be sure to turn on the caliper closed, that way it calibrates properly.
さんによる
The screw was measured by placing in the caliper as shown in picture.[image|1139208]
さんによる
Hi MSFA ! Do you have iphone 6s back camera grounding flex cable two screws size. And which end of the that cable go to which point. The one goes to the camera the other goes to the point next to the camera cable port. And could you measure for me those two screws size.
さんによる
1以上のコメントを表示
コメントを追加
i am using a magnetic screw chart mat like this one, works perfect
このアンサーは役に立ちましたか?
スコア 4
2 件のコメント:
What If you let fall down and all the screws spread in your so softly screw color carpet ? ?????
さんによる
I keep a strong magnet near my work. One screw will always attempt escape.
さんによる
コメントを追加
Do you measure the whole length or just to the head
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
The whole screw, head and thread
さんによる
コメントを追加
回答を追加する
craigad24 さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 27
過去 30 日: 134
今までの合計 134,953
