USB 3.0 replacement on the left side
OK i was using it in class and stuffed it in my bag to move classes and the flash drive took out the USB inter face on the laptop how can i replace the USB port on the left side of the laptop
この質問は役に立ちましたか?
この質問は役に立ちましたか?
If you, or someone you know is good at soldering, you can get the USB interface port online. If not, I would take it to a professional.
このアンサーは役に立ちましたか?
thank you i think i might get it services also do you think that if i send it in to asus they can fix it or would it be cheaper to get it done local in baton rouge
I would get it done local, It's a pretty easy repair. If you send it to ASUS...You may be without a computer for a good while.
thank you im going to get it done local
過去 24時間: 0
過去 7 日: 1
過去 30 日: 11
今までの合計 790
