Flash will not pop up
The flash no longer pops up, when it should.
Adjust the hotshoe. Loosen it off and check the contact in the middle, as is sometimes stays depressed/gets caught when you remove the external flash. The camera thinks it has a flash attached and prevents the pop-up flash from coming up.
このアンサーは役に立ちましたか?
The 5d doesn't have a built in flash. You need to fit an external flash!
このアンサーは役に立ちましたか?
Hi Sally,
The Canon 5D is a full frame DSLR camera and has no built-in flash. So, I am assuming you are talking about an external flash (like a Canon Speedlite) which you attach to the hot shoe of the camera.
Tell us more about the flash (brand, type, etc.) and what settings you used when the issue occurred.
このアンサーは役に立ちましたか?
Eos 5 film had a pop up, but not the 5D
My Eos 500d has a pop up... Are you confusing the 5d
with the 500d??
このアンサーは役に立ちましたか?
with the 500d??
過去 24時間: 0
過去 7 日: 10
過去 30 日: 20
今までの合計 1,112
