メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
一般ユーザー向けに設計されたAcerの15.6インチWindowsノートパソコンシリーズ。
Quick question about adding RAM
Hello, my computer is a Acer Aspire 5742G, everything is as it was bought but recently due to overheating issues I dissassemblied it and cleaned the fan. Since then (or maybe a while after, I'm not quite sure), I started noticing it was getting very slow so I paid attention to my RAM and noticed only 2GB was being used (Computer Properties and Task Host say so) from the 4GB built in when purchased. I tried switching the RAMs' slots between themselves but only 2GB was being used still. I'm assuming I damaged one of the RAMs when I dissassemblied the computer so I'm going to replace it.
My questions are:
1-Is there any other reason why it's only using 2GB or am I right in assuming I damaged one of the modules?
2-Could I buy a 4GB module and have it pair with my working 2GB one? Then I'd have 4GB+2GB=6GB RAM. I haven't made up my mind whether I should or not buy a pair of 4GB modules so this could be a nice alternative.
Thank you in advance :)
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
Hi,
Your computer support 8 gb ram (4+4)
So u can upgrade it to 8gb.
If you format ur pc before heating problem start even you clean the inside it s gonna be heat and shutdown. For fix this problem. You need to go acer web site and install the power management software than it s gonna be solve ur problem good luck
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
ruimendes10 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 11
今までの合計 454
