メインコンテンツにスキップ
衣類は肌寒い天候の日には体を温め、雨の日には濡れないようドライに体を保ってくれます。衣類の修理の難易度は破れた箇所を簡単なパッチで縫い合わせるものから、複雑な修理作業にまでおよびます。
171回答 すべてを表示
How to repair tear in patagonia rain jacket
Hi, I have a nice and new Patagonia rain jacket, 2 weeks ago I slipped when coming down a hill and made a 1/2 inch L-shaped tear in the sleeve. I could just stick on duct tape, but have you any other tips?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
ベストアンサー
Is your jacket a rain jacket or a baffled jacket (like a down jacket or Nano Puff)? The repair process for each is slightly different. In either case, you will need to patch over the whole tear to prevent water from seeping in. You may even need to sew the old material down underneath the patch.
We have a guide on how to patch a baffled jacket here: パタゴニアのダウン・ジャケットのバッフルの修理方法
For a regular rain jacket, you can apply a watch of waterproof fabric over the top and sew it down along the edge. You will want to fold the edges of the patch under so that they are caught in the stitching. You can follow the steps in this guide for a basic patching procedure: 形状バッフルでPatagonia ジャケットを修理する方法
If you need additional help you can contact Patagonia customer service.
Good luck and let us know how it goes!
Patagonia Down Jacketの画像
ガイド
難易度:
難しい
40 minutes - 1 hour
Patagonia Nano Puff Jacketの画像
ガイド
難易度:
中レベル
30 minutes
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
最も参考になった回答
Hi @selma0613
The image, was taken from the Patagonia Australia website. http://www.patagonia.com.au/worn-wear (scroll about 1/2 way down the page in the link to find it).
(Click on this image to enlarge it for better viewing).
It says that they will fix your problem for FREE. Hopefully this applies to the Patagonia branch where you are as well, if not in Australia.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I have a rain jacket that has a tore in the front of the jacket. The inside of the jacket is made to keep you warm. Is there is a patch that would stick or scretch with the material. I will decorate the patch since it's in the front of the jacket.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
paul o'raw さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 14
過去 30 日: 34
今までの合計 6,971
