メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Guitar HeroビデオゲームシリーズのGuitar Hero III用ギター型コントローラー。
Broken Connection - blinking lights
Hi Fellas,
up to now my Guitar worked fine. Just today as I tried to connect it seems to connect as Controller No. 2 but the other lights keep flashing and nothing works.
USB connector is unlikely because my other Guitar connects fine and the Broken one doesn't work with my Second connector as well. So I assume the Receiver of the Guitar.
My Problem is now I found no hint where to look for the Receiver Inside the Guitar. Do you have any Info for me about that?
Thx in Advance.
Bye,
Ferdinand
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 8
1件のコメント
Ive also had this problem and replaced the 220uF @10v capacitor but it still does not work
さんによる 共有
コメントを追加
5件の回答
最も参考になった回答
I had the same issue. Controller used to work fine, but after a few years I discovered it wouldn't synch. I tried my other guitar with the USB dongle and that synced, so I knew it was the guitar. I replaced the 220uF @10v capacitor on the main circuit board and it fixed the problem.
Probably a good idea to also replace the 47uF @10v too, since the factory components are poor quality.
このアンサーは役に立ちましたか?
スコア 3
5 件のコメント:
I replaced the capacitor and the problem persists. Any ideas?
さんによる 共有
The 220uF capacitor change worked for me. Previously, the LEDs blinked in sequence but never synced to the dongle, but now fixed once capacitor was replaced. Thanks.
さんによる 共有
It's the correct fix done a few with same issue.. If it's not worked check soldering or polarity or replacement capacitors...
さんによる 共有
Great! Just replacing the 220 one did the job here! Thanks!
さんによる 共有
For any chance do you guys have a photo of where the 220 uF 10v capacitor is located ?
さんによる 共有
コメントを追加
Worked for me: http://www.fixya.com/support/t1232769-it...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hey Ferdinand,
i got the exact same problem.
Do you have any new information or solutions?
Regards,
Henning
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
i’m having this problem where it flickers irregularly. it’s happening on 2 guitars, 2 sets of batteries, both when the receiver is connected directly to the PS3 as well as PC (no hubs). sadly, i don’t know where my other receiver is.
here’s what it looks like: Guitar Hero 3 controller glitching / random flickering - YouTube
any idea the likelihood of it being the receiver?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
More than likely be capacitors in the guitars they are known to fail giving the exact symptom you describe
さんによる 共有
コメントを追加
Capacitors on the les paul gibson model suck jus got one the other day and has this syncing problem what makes this even worse are the screws #0 square like are we serious 🤣
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Gardovan さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 19
過去 30 日: 103
今までの合計 44,843
