メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung Chromebook XE303C12-A01USは、11.6インチの画面と16 GBのSSDハードドライブを搭載したノートパソコンです。この小型ノートパソコンは、インターネットへのアクセスが容易で、さまざまなウェブアプリを実行できます。
How do I replace the power jack?
The power jack in my chromebook model XE303C12-AO1US is totally busted. I can't find a tutorial anywhere. Can you help?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
Lucy, the DC in jack is a separate cable which connects to the logic board. It is available at places like this. I would use the teardown from here as an idea on how to get inside your Chromebook.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
the ebay link provided is not working anymore. can you give me a hint where can I find a replacement power DC jack?
さんによる
コメントを追加
All you have to do is first follow the teardown to get the back panel off. Don't need to even take the battery out (it may be safer for your hardware if you do - but I didn't). After that the power jack can be released by removing the screw, then lifting the clip and unhooking on the side opposite the screw hole. Then at the other end of the harness, the cable has a small plug which goes into the motherboard. The plug has 2 tabs, one on each of the short edges, while the wires go into one of the long edges. These tabs are held by small metal clips that need to be gently pushed out just a little as the plug is lifted. Gently slide a thin blade or screwdriver under the wires and a bit under the plug, and apply a little pressure to lift the plug. While you are lifting, use something small like a jewelers screwdriver (or the corner of a slightly larger slot screwdriver) to push out the clips on each tab, one at a time. The plug should come up a bit, then slide out (towards the wire side). Then install a new plug/jack/harness more or less by following these instructions in reverse.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Lucy さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 32
今までの合計 2,766
