メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Nikon製 12.3メガピクセル DXフォーマット Fマウント デジタル一眼レフカメラ。
interval shooting timer , not selectable in any menu
I used the IST, once before , when to used it again , but it is not an available option any more. it is gray and all the info that I can get is that it does not work with bracketing settings .. any ideas
thanks
FR
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
4件の回答
最も参考になった回答
I had the same problem with interval not available. Took the 64G card out, 16G in. Interval available again.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
had the same issue.. didnt like my memory card.. I had used it week before.. then when I tried to turn on the camera it said the card was not formatted and I know there was data on it.. so now today I took the data off that card. put back in d5000 and it said it was not formatted .. I let it format it.. and now interval is off.. I threw in another SD card and its ok.. doesnt like this micro SD card now.. I have another one I have in there now.. but something is strange.. so try another SD card..
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Got the same problem.
- Tried bracketing off
- Tried inserting the date and time again.
- Tried a full battery.
- Tried resetting the camera (hold i button + info button together for a couple of seconds).
- Tried all possible modes and settings.
Then I've read somewhere to somebody had issues due his 64gb card. Now I see Kevin above here say something similair. Back in the day the D5000 came out, 64gb cards were not that normal. So I might buy a cheap 8gb and see if that resolves the problem. If not, I'm out of options.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi. I removed the battery and inserted back in and ITS worked again.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Frank RUiz さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 29
今までの合計 2,733
