メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2011年10月発売。GoProの第2世代アウトドア向けカムコーダー。プロのアスリートやスポーツ愛好家、コアなファンに使用されました。
Internal microphone does not work.
Hello,
I hum Problem with My GoPro Hero 2 from When I bought . Her microphone worked BY 15 days, since audio capture only with external microphone.
I saw several reports it can be the external connector that does not turn over the internal microphone , it proceeds ?
Is there any chance of getting the microphone and not the connector ?
thank you ,
Melvin Aster
from Brazil
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
Did you plugged external mic into your camera?
If yes - it is common problem in some versions of hero2.
You can change (upgrade or downgrade) firmware - there is no specified version that is works, you have to try.
Then you should do not connect any external microphone (because camera will lock again on external mic).
Some versions of hero2 works good on latest firmware (you can use external or internal mic), but some also locks at external mic.
No known workaround for this issue.
Update (10/27/2015)
Also it is possible that mic cable is broken - you can simply fix it as shown in this tutorial (speaker replacement), but by mistake someone called it speaker while it is internal mic :)
Also mic can be broken, so you need to buy new one.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
here is a link to the hero2 mic:
http://www.ebay.com/itm/GoPro-HD-Hero-96...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Melvin Aster さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 47
今までの合計 1,910
