メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Acer Iconia Tab B1ファミリーの最初のタブレットであるAcer Iconia Tab B1-A71は、2013年1月に発表されました。
Why the screen show White?
My Acer got white!! I was just playing some music, then i lay it down on the couch and went for something. When i returned the screen has got white and there was a crack in The middle, (not really, but it looked like an inside one ). But there was a black spot too. I turned it off and it turned black. Then i again turn on, but the screen appears as white ,black spot,and crack as it was. I tried to pull the notification bar. A sketch of bar appears but no icons or nothing. Help me please.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
ベストアンサー
Did you sit on your tablet? Or did it drop when you were away? Anyway, the fact is your tab lcd display was damaged.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
SO, should i have to change the lcd screen? And my sister was there too, according to her, the tablet was there laying, and it didnt even fall. She haven't lied. However, what to do with the tablet, and how to fix it??
さんによる
You mentioned that your tablet had cracks, spots and blank screen, these are all hardware issues not software issues. A replacement display can fix it. If you'd like to DIY repair it, this is the part: http://www.etradesupply.com/acer-iconia-... and this is the guide Acer Iconia B1-A71の液晶ディスプレイの交換
さんによる
コメントを追加
I have the same problem but my screen was already cracked
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Asad さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 11
今までの合計 2,707
