メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
別名:Sony Ericsson Xperia Nozomi、Sony Ericsson Arc HD
How to merge Internal memory and Device memory?
Hi,
Sony Xperia S LT26i, has Device memory of 1.97GB. However there is 25GB of Internal Storage memory. Device memory is so small that more than half of it is occupied by Android, leaving very small space for applications. This in-turn slows up the device as there is very little space is remaining. I want to merge the both the partitions (Device memory and Internal memory). Can you please help me on this. My Emailid is: gaurav.whitelotus@gmail.com.
Thanks in advance!
Gaurav
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 8
コメントを追加
3件の回答
最も参考になった回答
Hey,
It *IS* possible, thanks to XDA Dev mickybart.
Not easy process at all though, check this guide on XDA. Make sure to flash Android 7.1 in the end (https://forum.xda-developers.com/xperia-...)!
Your warranty will be void by doing this. If you run into problems, do not hesitate to ask at that forum (the 7.1 ROM thread.)
PS: Rooted phone is necessary :)
Good luck!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hi,
I have the same problem, the only way that i found is through rooting the phone and then using an app called "Move app to SD card".
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
can't move to SD card, any other solution?
さんによる
コメントを追加
Unfortunately this can't be done. The 2GB internal is actually the RAM and is where the apps actually run and will be occupied as you stated. The 25GB is like the hard drive of a computer. The 25GB is only for storage of apps and data. Try running an app that let's you force close apps (Clean sweep or 360 security) and has the added bonus of cleaning the junk off of your device. I run 360 on my phone and it keeps it running really fast.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Inncorect!!!
Sony xperia s have 32GB ssd but it's flipped in two partitions( one for the system and apps but other for other things).
And this phone only got 1GB of RAM.
さんによる
Why not provided SD card available
さんによる
コメントを追加
回答を追加する
Gaurav Singh さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 19
今までの合計 10,329
