メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Nikon D80は、2005年に一般発売された1,020万画素のデジタル一眼レフカメラです。デジタル写真の撮影や動画撮影を目的としています。
Err code on display . Camera stop responding.
My D80 shows err code. Try to change lens. Try change f stops. Still the same.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
1件のコメント
my cam had the same issue got it repaired at very less price at mata electronics. contact them at mataelectronics@Gmail.com
さんによる 共有
コメントを追加
1 件の回答
最も参考になった回答
Usually, on a Nikon D80 with an "err" message that won't go away, the Aperture Control Unit must be repaired or replaced. There is a small switch contact held on by a small plastic rivet in the Aperture Control Unit that tells the electronics module in the camera what phase the camera is in during its cocking cycle. When that small plastic rivet breaks, the camera can't determine where it is in the cycle and just stops and displays the "err" message.
There are 2 ways of fixing the problem, replacing the part with the same weak plastic-riveted switch contact or taking the Aperture Control Unit apart and replacing the plastic rivet with a small steel screw which can't break again. I've been using the second method for many years now and haven't had a single body experience the same problem again.
Bob Kilbourn
http://www.camerarepairs.com
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Hey Bob, where did you get this small screw from and what size of screw did you get? Thanks
さんによる 共有
コメントを追加
回答を追加する
AmranNazi さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 22
今までの合計 3,356
