How do I replace the keyboard?
How do I replace the keyboard on my laptop? I know that there is a tear on the left shift key pad that I found after removing the key to clean a sticky substance that I thought was the issue.
Hi Hurley,
As far as i know with the knowledge of the same model but from Packard Bell this laptop has sort of a "unibody" like a macbook.
U would have to remove the complete top cover by removing the screws sitting at the bottom and lift the top cover up as a whole to get to the keyboard.
Mind you that most of the times these top covers are extra mounted with clips so it might take a bit of effort to remove it. I would suggest to start from the front (the side of the touchpad) and move forward towards the back.
Hope this helps you in any way.
このアンサーは役に立ちましたか?
過去 24時間: 3
過去 7 日: 4
過去 30 日: 24
今までの合計 1,512
how would ou clean under the trackpad on this laptop? i have the same one and im wondering cause i need to clean mine
sabrina payne さんによる 共有
