How do I find replacement USB ports and replace?
Both ports are damaged. Need to find replacement parts and help in installing?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Here. Basically the USB ports are fixed to the logic board, however you can use a USB pcmcia card
If this answer is acceptable please return and mark it.
Good luck,
N.
このアンサーは役に立ちましたか?
How would it connect to my computer, if both ports are damaged? Would I need a specific card? Thanks for the response.
Um I need the liquid used to de soldier the USB port, anyone know what the liquid is called
過去 24時間: 0
過去 7 日: 1
過去 30 日: 21
今までの合計 2,571
