メインコンテンツにスキップ
2008年10月発売。2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duoプロセッサ。
376回答 すべてを表示
締切られた回答
Internal Seagate 1TB Hybrid boot drive not recognized
I'm trying to install a new hybrid drive in a Macbook's standard HDD bay. I formatted it on a Core i3 iMac, and installed Mavericks. It works fine externally (via USB) and will boot on the iMac. But the Macbook Pro (Core 2 Duo) does not recognize the boot partition, and just shows the folder [?] on startup.
There are two partitions on the drive (300GB and 700GB). Seagate says the SATA III is backwards compatible, but Mayer here suggested using a jumper to drop the transfer speed. I'm not sure how best to do that (can I just fashion a jumper from a paperclip?) or if it would work on this model.
Is it possible the Core 2 Duo will not support a drive this large? Thanks for any responses.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
4 件のコメント
UPDATE: I was able to startup the Macbook from this new drive externally) (using my iFixit USB adapter!). So it is not a compatibility issue, but a problem with the internal connection I would think.
The original hard drive had mechanical failure after being dropped. Could that have damaged the internal cable as well? Seems a remote possibility.
さんによる
ADDITIONAL UPDATE:
- Installing a new HD cable did not solve the problem.
- An older HD (SATA I) worked fine when installed in the drive bay.
- Putting a jumper on the 2 leftmost pins of the 1TB Seagate drive did not solve problem.
I am reluctant to reformat the 1TB drive as a single partition, but that's the last possibility I can think of. I'll probably put it into an external case and get a smaller, slower drive for internal use.
さんによる
SUCCESS AT LAST: Seagate drive working as intended. The SATA cable and connection are fine. Must conclude that the problem was in the drive itself, and the way it was initially formatted. Further comments below.
さんによる
Happy to here it's working!
さんによる
コメントを追加
2件の回答
ベストアンサー
How about checking the systems firmware, Apple did make some alterations that do effect Auto SATA speed sensing HD's. Follow this Apple TN on how to check and update: EFI and SMC firmware updates for Intel-based Macs
このアンサーは役に立ちましたか?
スコア 2
6 件のコメント:
Thanks, Dan. The Boot ROM version appears to be up to date. But I downloaded the updater anyway, and tried to install it while booted from the external hybrid drive. I got a message saying "this software is not supported on your system." Mysterious....
さんによる
A possible clue: I have a saved system profile with the original hard drive date. Under SATA/SATA Express data it says the disk S.M.A.R.T. status is "verified." The current system profile, with the new drive external under Storage lists the S.M.A.R.T status as "not supported." Is that significant?
さんによる
OK, good to hear the firmware is OK, The reason you can't see the SMART is the I/O is not native SATA (USB or FireWire accessed)
さんによる
The only thing left is the SATA cable is bad. FYI - Your system can support much larger HD so thats not the issue.
さんによる
You're right, I'm afraid. I found another thread on the topic (Internal hard drive disk not recognized) and even tried the masking tape trick suggested within, but no luck. Hoping Apple will offer a replacement...
さんによる
1以上のコメントを表示
コメントを追加
I have to un-accept this answer, I'm afraid. I installed a new HD cable, but am still having the problem. The question now (based on what I've read here and elsewhere) is:
Do I need to jumper the drive to run at 3.0Gb? Or, should I reformat the drive as one partition?
Opinions welcome!
The firmware is up to date, the Mac will support 1TB and the SATA drives are supposed to be downwards compatible. Theis one is SATA III 6 .0GB (Seagate model 1000LM014) with 2 partitions (300Gb and 700 GB). When running it externally via USB, both partitions mount and I get these system reports:
Hardware Overview:
Model Name: MacBook Pro
Model Identifier: MacBookPro5,1
Processor Name: Intel Core 2 Duo
Processor Speed: 2.53 GHz
Number of Processors: 1
Total Number of Cores: 2
L2 Cache: 6 MB
Memory: 4 GB
Bus Speed: 1.07 GHz
Boot ROM Version: MBP51.007E.B06
SMC Version (system): 1.33f8
Serial Number (system): W88480021GN
Hardware UUID: 26BA7B20-2AC2-530F-98AD-C3DEA148B0F4
SATA/SATA Express:
NVidia MCP79 AHCI:
Vendor: NVidia
Product: MCP79 AHCI
Link Speed: 3 Gigabit
Description: AHCI Version 1.20 Supported
Storage:
Galehead:
Available: 105.72 GB (105,719,644,160 bytes)
Capacity: 299.49 GB (299,489,112,064 bytes)
Mount Point: /
File System: Journaled HFS+
Writable: Yes
Ignore Ownership: No
BSD Name: disk0s2
Volume UUID: 087BFEBE-D55F-3F14-8850-CA815D191E6A
Physical Drive:
Media Name: ST1000LM 014-1EJ164 Media
Protocol: USB
Internal: No
Partition Map Type: GPT (GUID Partition Table)
S.M.A.R.T. Status: Not Supported
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Did you inspect the cable connector on the logic board to see if it is damaged. You'll likely need a magnifying glass to see things. Something just isn't adding up here. Known working drive, replaced SATA cable; Only thing left is damaged logic board connector or a drive thats firmware is out of date.
さんによる
I checked the Seagate site for firmware downloads - they don't list one for this model (ST1000LM014). I bought the drive bare (out-of-box) so perhaps it had been used. An older drive (SATA I) works fine with this cable and logic board, though.
Thanks for paying attention, Dan. I am going to try to get to the bottom of this and report back.
さんによる
To recap (as best I can recall): the 1TB drive came in OEM packaging. I connected it to an iMac via USB, with an iFixit adapter, formatted it with 2 partitions using Disk Utility, and transferred my data using Time Machine.
After the problems described above, I bought a 320GB SATAII drive and an Inland USB external enclosure. Formatted that drive using the iMac and new enclosure, had no trouble running it inside Macbook. Then put the 1TB drive in the new enclosure w/o jumper, and connected it to Macbook. Disk Utility told me it only had a 128GB Master Book Partition! Using it with the iFixit USB adapter, I could see the GUID partitions, which was baffling. So I put it back into the Inland enclosure, and used the Macbook to completely reformat it and reinstall the OS. And that finally did the trick - it would start up Macbook internally. Somehow the hybrid 1TB drive had a boot partition that survived 2 attempts at reformatting.
さんによる
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 5
今までの合計 2,482
