メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Microsoft Wedge Touch Mouseは、Microsoftが発売した両利き用コンピューターマウスです。
Stuck at step one
I had a corroded battery and need to clean the contacts. This post has detailed steps but I can't get past step one.
The cover just will not come off. I can easily pry up the edges but it feels like there's something in the middle of the top plate that's attached and I don't want to break the mouse.
Step one mentions about moving the pick tool along the edge towards the battery cover and mentions a pin I believe. This just doesn't seem to work and I don't know what to do next.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Steve,
That would be a cable which is connected there. It has enough length that you should be able to separate the two covers if you do it firmly/gently/controlled. Just realised your questions is from 2014. Hope you figured it out.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Steve さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 22
今までの合計 704
