メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2013年8月に発売された、HTC Oneのコンパクトモデル。
Powering on with a broken power button
Hello guys, I've been having kind of a big problem with my HTC. I dropped it a few times and the casing tore away from the top part and the bottom part of my phone, including the power button. normally I'd just get a new casing so I could use it, but the mechanism itself tore off too, meaning that getting a new button or casing won't really fix it.
I was wondering if there is a way to boot up my phone through my pc. I've been searching around and it seems to be fairly simple for most Android phones, however, since HTC One's block your access to the battery, I cannot use any of the tips others give me.
I do not have warranty anymore, so I'm not afraid of doing the bigger things. It is also rooted.
Right now, the phone is still on and I wake it up by using lock widgets and using the volume button. I am however still scared about not being able to charge it on time to keep it alive.
Thanks in advance!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
i am in your place but it had turned off
さんによる
コメントを追加
1 件の回答
最も参考になった回答
it's pretty easy if i remember right that power button does not require soldering so just order a new part and pop it in.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
as in disconnect the old broken one and connect that one.
さんによる
how to reboot my htc one mini not working my power botton
さんによる
コメントを追加
回答を追加する
Alperen さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 13
今までの合計 3,760
