LOGITECH G27 Racing Wheel
my g27 wheel has no force feedback and the shifter and clutch pedals don't work. The wheel works and all the buttons work. Thinking it might be the motor?
Hi, Regarding your wheels lack of force feedback, it could be that the motors in your wheel are either broken or stripped. However I would check in-game settings to make sure before disassembling your wheel. As for the shifter and clutch pedal I can think of only two things that would make those not work. Either the potentiometer in the shifter is broken and needs to be replaced, or the whole setup is having a connectivity problem with your gaming device. The potentiometer can be replaced relatively easily however the connection problem would be much harder to find then solve.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 10
過去 30 日: 27
今までの合計 858
