Repaced digitizer not working
Is there anyway I can identify which version of digitizer I require, as the new one doesn't allow touch, without having the original screen to hand? Thanks
Hi Jez,
When ordering the digitizer, try to match up your specific model number to the part you are ordering. There are times when you can accidentally order a 4g screen for a wi-fi only model and not have it work. I wouldn't say this is down to revision number on the digitizer itself and the most likely cause is that the part is incorrect for that model itself.
このアンサーは役に立ちましたか?
過去 24時間: 3
過去 7 日: 3
過去 30 日: 9
今までの合計 267
